Camshaft Opinion Please
Posted 21 May 2013 - 10:53 PM
My question is whether I should stick with the metro cam. Would a 266, 276 or sw5 be better?
The engine will be mated to a decent ported head and hif44. Dizzy will be DM65. Box standard.
I drive mostly at weekends, round the lanes. I'm not rev heavy and prefer low to mid pull over top end grunt. In fact I rarely see over 4k socwant my fun under that.
One more thing, I have a choice of 3.4 or 3.1 final drive. I'm leaning towards the 3.1 but will go 3.4 if it gives a better balance.
I'd appreciate any thoughts, thanks.
Posted 21 May 2013 - 11:03 PM
If you never go over 4000 rpm then a 276 is most certainly not for you because it gives peak power at about 6100 rpm. With the MG Metro cam peak power is about 5700 rpm and peak torque at about 4100 rpm, plus or minus a bit, so the MG Metro cam is about ideal. The 266 is virtually identical to the MG Metro cam. I've not worked with the SW5, but it must be similar.
FDR is personal choice depending on whether you want more acceleration or a better cruising rpm at a given speed. A 3.44:1 will give about 66 mph in top at 4000 rpm.
Posted 21 May 2013 - 11:06 PM
I'd go with the SW5. my local engine builder raves about them.
Posted 21 May 2013 - 11:09 PM
Fd bothers me. I want to floor it and feel it!
Posted 21 May 2013 - 11:10 PM
Does your man say why he likes it so much?
Posted 21 May 2013 - 11:20 PM
I think low end torque and drivability where his key points on it. He was only on the phone to Dad today talking about one they'd recently installed on an MG Midget.
He runs Tipton Garage with his son down here in Devon. Richard the owners used to work for Downton and his son used to work in the engine department for the NIssan BTCC team when they where running Primera's.
Posted 21 May 2013 - 11:25 PM
That ties with what I've heard, thanks. I'm persuaded its a great cam, as is the 266 and mg metro.
I'd love an opinion of the real world differences if anyone has experience.
Posted 22 May 2013 - 04:40 PM
yes I agree with Tuppers as I have an SW5 in my engine and the low end torque is brilliant and of course the mid and top are fab.............. ![]()
Posted 22 May 2013 - 06:39 PM
In order to successfully compare to profiles you need to look at the overlap lift, lobe separation and total lobe lift figures. If these are the same the cams are going to give you the same characteristics.
ACD
Edited by ACDodd, 22 May 2013 - 06:43 PM.
Posted 22 May 2013 - 08:22 PM
AC, sw5's are pricey. How much is yours? Pm me if you could please.
Posted 22 May 2013 - 08:42 PM
All my cams are £105 exchange, 6 in the range from stock to sprint,
PM sent.
AC
