Coil Wiring
1 reply to this topic
#1 4l1x
4l1x
  • 27 posts
  • Local Club: Basingstoke
Posted 22 May 2013 - 12:22 AM
hi there, i have just refitted my engine and cant remember how the coil was wired up. i have the lucas sport coil (gold one) and lumenition ignition. the car cranks over but no spark. i know the white and black wire goes to the - for the tacho and the white and yellow goes to the starter on the +, the pink and white wire is unused but where do the two wires from the dizzy (red and black) go and how do you get a feed to the coil as i have no volts getting to it?
cheers
#2 Ethel
  • 26,581 posts
Posted 22 May 2013 - 01:22 AM
red to coil +ve, black to coil -ve.
Your loom is for ballasted ignition, if your coil is 12v (3 ohms resistance) and if your Lumenition kit is also for 12v unballasted, you just need to add a wire between the coil +ve and an ignition live feed - you can jockey one off the fusebox terminal with a white wire attached.
