Fused Or Not
9 replies to this topic
#1 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 22 May 2013 - 06:18 AM
Hi. Got a 1991 998 with ballasted coil.
I am going to fit a powerspark ignition kit and need to take a feed from the fuse box.
Do I take it from the fused or un-fused side?
Jim
#2 grahama
grahama
  • 2,442 posts
Posted 22 May 2013 - 06:51 AM
The ballast wire comes from the top fuse anyway which is switched live from the ignition. I have not fitted one of your kits yet but would imagine you would need to run your live feed from there.
#3 tiger99
tiger99
  • 8,584 posts
Posted 22 May 2013 - 07:05 AM
Normally from the unfused side (white wires). You don't want the engine cutting ouit if the fuse blows due to overload by some other less important thing.
But there is no reason why you can not add an extra fuse specifically to protect the ignition system only.
#4 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 22 May 2013 - 04:32 PM
Nice idea. I guess a switch in line in addition would make a handy immobiliser too.
#5 Ethel
  • 26,581 posts
Posted 22 May 2013 - 04:48 PM
A switch to earth off the -ve side of the coil makes a craftier immobiliser.
Personally I'd never fuse ignition, it's just something else to fail (at the most inopportune moment) and you should be within easy reach of the ignition switch whenever it's turned on.
#6 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 22 May 2013 - 05:06 PM
Just a switched wire from coil -ve to earth?
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 22 May 2013 - 05:10 PM
yes when points open and shut they are connecting the negative side of the coil to earth when points are closed..when they open you get the spark at the points.
So if you fit the immobiliser switch so it makes a permanent contact between earth and the negative coil terminal it cant spark.
#8 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 22 May 2013 - 07:43 PM
Thanks. Good advice.
#9 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 24 May 2013 - 05:09 AM
Don't like this at all. But anyway according to the drawings I have, everything ignition dependent is fused in any case.
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 24 May 2013 - 06:00 AM
Coil is non fused Captain...it takes a feed from the white wires in the loom...white wires are ignition switched non fused...The greens are ignition switched fused.
