Megajolt Help How Do People Set Them Up ?
5 replies to this topic
#1 oliver122
oliver122
  • 1,007 posts
Posted 22 May 2013 - 08:17 AM
hey guys so im going try get my mini kick in on megajolt tonight but was wondering how people go about changing the advance to get it running , not editing it but setting it up , would a timing light be much use as ive got one i can use ? any help would be great guys
#2 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 22 May 2013 - 08:55 AM
What engine spec is it and what map have you used as a starting point?
Megajolt has a 'limp home' feature,  where if the mj box isn't connected/working the edis will give a fixed 10 degrees advance, which will be enough to start the engine.
For a first start just make sure everything is as it should be, trigger wheel and sensor correct, dizzy drive removed etc and spin it over.
#3 oliver122
oliver122
  • 1,007 posts
Posted 22 May 2013 - 09:03 AM
we have had it running just on the edis and on the mj with the base map in , ive uploaded the spi md286 off there website(had to do it at work as i dont have the adapter or a comms port on my laptop) as ive been told thats a good starting point my engine spec is :
1275
276 kent cam
stage 3 polished and ported head
hiff 44 k and n cone filter with stub stack
maniflow stage 2 lcb
rc40 twin box
Edited by oliver122, 22 May 2013 - 09:04 AM.
#4 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 22 May 2013 - 09:20 AM
Well if it's running and driving you've got over the biggest hurdle. Now you can either play around with the map yourself on the road (if you buy a adapter to connect the mj to a sub slot(see Amazon)) and get it to what feels best or take it to a rolling road and get someone who knows what they're doing to tweak the map to find what makes the best power curve.
#5 Ethel
  • 26,581 posts
Posted 22 May 2013 - 10:42 AM
You really need a lead to be able to tune it properly. You can get a USB to serial adapter, the compatibility issue isn't so bad, I use an ebay cheaply (translucent turquoise ) it does all but flash firmware. You'll also need to cobble together  a rj45 to db9 lead (unless you mj is an oldy) - ebay again. You'll then be able to try out adjustments as you're driving along (best to have a copilot to operate the lap to!), or use the 2nd map option for an optition style "better or worse" session.
Without a lead the most you could do is use you strobe to the actual advance you are getting, using the edis limp home.
#6 Ethel
  • 26,581 posts
Posted 22 May 2013 - 11:08 AM
Mine only cost a couple of quid, but having a garage lappy to not worry so much about grubby fingers is a good idea anyway.
