Heelboard Replacement
Posted 22 May 2013 - 10:23 AM
Pan how much would it cost to replace both!!!
Posted 22 May 2013 - 10:27 AM
Depends on where you go, front floor pan probs about £120ish, but the heel board is alot more complex as you have to remove the rear subframe. So probs about £450 for that.
But prices can vary soo much from place to place. Iv seen people be charged over £300 for just the front floor pan one side.
Posted 22 May 2013 - 04:25 PM
Posted 22 May 2013 - 05:31 PM
If both ends of the floor have gine the chances are the bit in the middle will have gone as well. Might be cheaper in the long run and will certainly result in a far better fix to replace the whole floor panel with the heel board and inner sills already assembled
Posted 22 May 2013 - 05:59 PM
