Y Piece So Close To Tunnel
18 replies to this topic
#1 marsy
marsy
  • 374 posts
Posted 22 May 2013 - 02:03 PM
Please see pics attached, not the best but is my y piece fitted right? As it seems so close to the side of tunnel, should it be a bit more central? Is there other y pieces? Or are they all the same shape? Thanks
#2 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 22 May 2013 - 02:34 PM
seems okay from the photos, bear in mind that the exhaust has to pass beside the gear linkage
#3 petehuws
petehuws
  • 329 posts
Posted 22 May 2013 - 04:34 PM
Looks OK from me too!  I need to pop out to my garage in a short while I'll try to post a pic of mine but I'm guessing it looks the same, I don't see anything wrong.
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 22 May 2013 - 04:45 PM
I hope this helps........ :proud:
#5 marsy
marsy
  • 374 posts
Posted 22 May 2013 - 05:12 PM
Wow!  great mk1leg! Have you got a clamp on the y piece to the centre section?? The one I've got just about clears the tunnel, but any movement and it touches, then vibrates, annoying!:(
#6 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 22 May 2013 - 06:23 PM
What down pipes have you got
#7 marsy
marsy
  • 374 posts
Posted 22 May 2013 - 07:18 PM
Got a straight through rc40 stainless link pipe, which way round should it fit? The bend near the y piece? Or straight then the bend nearer the exhaust end? Thanks
#8 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 May 2013 - 06:33 AM
I mean the outlet manifold pipes coming from the engine.
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 23 May 2013 - 06:35 AM
Just looked at mine which is a single box rc40 and the bent bit goes at the rear
#10 marsy
marsy
  • 374 posts
Posted 23 May 2013 - 08:50 AM
I don't know to be honest, I brought it as part of a job lot, so don't know, sorry!:(
#11 marsy
marsy
  • 374 posts
Posted 23 May 2013 - 08:51 AM
Ahh thankyou!
#12 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 23 May 2013 - 10:44 AM
even on my car(1989 998cc) its quite tight
#13 MiniAbbott1993
MiniAbbott1993
  • Validating
  • 39 posts
  • Local Club: Essex Mini Club
Posted 23 May 2013 - 12:29 PM
Does the Y-piece bend off to one size when it joins to a single bore?
looks like it does from the 4th photo
Also looks like the two manifold pipes sit closer to the driver side of the channel?
Try setting up so the Y-piece branches more into the centre so the pipe runs down the channel.
That way the pipe should be a little further away from the wall of the channel and should hopefully help with the vibrations.
The length of pipe you have from manifold to rear box, does it have bends on either end?
You should be able to arrange the piping you've got to divert the pipe around the gear change.
I find that i've had to mess around with trying different ends of pipe to get a nice fitting set up.
From my experience with two different mini's and LCB set ups, I think it depends what patent brand you go for as to how much trouble it might bring to set up.
#14 marsy
marsy
  • 374 posts
Posted 23 May 2013 - 12:45 PM
Does the y-piece bend off to one size when it joins to a single bore?
Hi yes the y piece does bend off to one side, and
 upwards i think. And the manifold pipes yes are bent, but it looks as if one have been cut slightly, and one in shorter than the other!
Thanks for your reply!!
#15 MiniAbbott1993
MiniAbbott1993
  • Validating
  • 39 posts
Posted 01 June 2013 - 03:03 PM
Okay, might be a bit of trial and error to get a nice fit then, which shouldn't be a problem.
The bends are just to help channel the pipe around the gear change ect.
Both of mine needed the same thing when fitting.
I'd advise dry fitting the pipes in place first so you are certain that it will all fit as it is.
Then once you know it all fits,  take it all apart then cake the mating surfaces of the pipes with exhaust paste just to be safe.
It's definitely worth it while you're under it rather than come across a horrible blowing noise when you start it up and only have to get under it to paste in anyway
Hope all goes well :)
