Hey people.
The rear rubber to secure exhaust to body of my car is badly worn as shown in photo below. Another mini owner gave me a new part but I'm not sure if its right? :
Carl
Best Answer lrostoke , 23 May 2013 - 11:24 AM
If that u bolt is holding the hanger bracket then should be able to adjust it a bit I'd think.
Supposed to be fairly tight or else it would just bounce around :)
Go to the full post
Posted 23 May 2013 - 11:11 AM
Looking at that it looks like some bodged up silencer and fitting.
looks like its touching the battery box shouldn't be that far across.
and the hanger on the subframe looks to be held on by that U bolt.
Later models did use rubber hangers but yours is some DIY effort so you'll have to see if it fits
Posted 23 May 2013 - 11:17 AM
Why is the exhaust on the wrong side of the car?
Posted 23 May 2013 - 11:18 AM
Posted 23 May 2013 - 11:19 AM
Posted 23 May 2013 - 11:24 AM Best Answer
If you want to keep that exhaust, which should probably be replaced with something more appropriate really, the best thing would be to fabricate a new hanger bracket for the subframe. Exhaust hangers are meant to the vertical-ish really, and not so stretched. I would say the new one you have been given is the same as the one fitted now, but the original has been forced to fit and so been destroyed.
Posted 23 May 2013 - 11:30 AM
Ah ok thanks. I'll have a look to see if i can adjust it. Thanks :)
Posted 23 May 2013 - 11:32 AM
Ah that makes sense. Was thinking about one day changing exhaust but at the moment it'll do. Bit short of money after paint job and getting ultralites refurbished next week.
Posted 26 May 2013 - 02:02 PM
Got the new one fitted :)
It took forever to get the old one off. Had to cut it off. The U bracket was over tightened and twisted round so I couldn't easily get to the two bolts to loosen them. That prob explains why the old one ended up in condition it was lol
Edited by Carlsmini, 26 May 2013 - 02:04 PM.
