I'm just about to start my rebuild (big ends, main bearings, thrust washers, piston rings, new race cam, etc etc etc) - I'll be lube-ing the cam and shells etc with redline build lube, what is a good oil to use for a break-in period? maximum protection etc? something with a high ZDDP content i assume?
Thanks!
Oil For Breaking In Rebuilt Engine
Posted 23 May 2013 - 01:54 PM
Posted 26 May 2013 - 10:26 AM
Anyone ?!!
Posted 26 May 2013 - 11:59 AM
I'm about to use cheap Wilko 20/50 and change it very often.
was the block honed as well as new rings?
Posted 26 May 2013 - 01:15 PM
Thanks!
With honed bores and new rings - maximum protection is just what you don't want. You need to knock the peaks of the honing and settle the rings down - too sedate a drive together with friction inhibitors will cause problems.
Posted 26 May 2013 - 02:52 PM
an interesting point!
Although i was thinking more about the cam and followers....
Posted 26 May 2013 - 03:04 PM
Thanks!
Yes, mineral 20w50 with high ZDDP content such as comma sonic 20w50.
Avoid synth oils and 'classic range' oils.
