Anyone got one in decent enough condition? Don't mind doing work on it as long as its straight and cheap enough....if not i'll be buying brand new.
Located near Macclesfield, so if you are miles away, postage will be required
Posted 23 May 2013 - 06:17 PM
Posted 23 May 2013 - 08:15 PM
i got a metal one, currently working in staffoed so could meet up some where?
Posted 23 May 2013 - 08:40 PM
Cheers, but i've got a metal one.....wanted a F/G one to save a bit of weight and want to mount it on bonnet pins and didn't want to drill my steel one.
Posted 23 May 2013 - 08:48 PM
Posted 23 May 2013 - 08:51 PM
There's one sat on my drive at the end of the cat and fiddle. but im not sure its what you want. cracked chipped and bent
You really are selling it to me...ha ha. Is it rescuable...and is it cheap?
Posted 23 May 2013 - 08:59 PM
Posted 23 May 2013 - 09:02 PM
Well its free. so yeah its cheap. wind blew it off whilst driving. bonnet corners still attached to car with pins in. so imagine a normal bonnet with no corners a crack up the middle about half way. oh it got 3 paving slabs holding it on to the car now so its also bent.
its proper goosed. but thought id tell you i got one.
Sounds like its past helping then
Posted 23 May 2013 - 09:07 PM
Posted 23 May 2013 - 09:22 PM
Mine was a mega thin and light. the wind used to lift it right above the badge on the grill when doing anything above 35. It just took that one gust of wind and off she flew. so just watch for this when you find one
Cheera man....will probably get one and create a crossmember to stiffen it up to stop flexing and turning the bonnet into a kite!!!!
