Few Reactions !
10 replies to this topic
#1 grahama
grahama
  • 2,442 posts
Posted 23 May 2013 - 06:56 PM
Hi all,
I am as you may know rollering rustoleum on the mini,  first coat went on fine,  second ok but I have had a couple of issues.
I am using a new pot of paint from Avenue coatings,  new rollers,  new tray and sponge brushes.  I have thoroughly panel wiped down the body and tack clothed.
I did notice in the tray a bit of 'split' paint,  as if it wasn't holding together or mixing with the thinners properly,  but had no problems before with the paint/thinner combination.
Pics
As the bonnet shows,  it is as if there is something on the roller,  or maybe in the tray, (left over release agent from manufacture) ??  Maybe the glue in the roller itself is to blame when applying a little pressure,  am at a loss.  Very annoyed though as the first coat went on fine with less panel wiping than this coat.
Could wet sand residue cause this??  Any ideas are appreciated in cause and how to treat the areas??
many thanks, again,
Graham
#2 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 23 May 2013 - 07:00 PM
look on you tube mate good tips there
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 23 May 2013 - 07:02 PM
that has reacted with something
i just wash everything down with white spirit and slap it on no where near your amount of prep and never had any problems
i have covered all sorts of layers of old paint
Edited by Bungle, 23 May 2013 - 07:02 PM.
#4 grahama
grahama
  • 2,442 posts
Posted 23 May 2013 - 07:03 PM
I have looked exhaustively on u tube about rollering rustoleum,  and the reaction I am having is over rustoleum 1st coat so not a paint reaction.  Looking for some common reaction sources like having to rince rollers in white spirit first before using or washing everything in washing up liquid before use due to contaminates.
thanks tho,
Graham
#5 grahama
grahama
  • 2,442 posts
Posted 23 May 2013 - 07:04 PM
Was that covered with rustoleum Bungle??
#6 grahama
grahama
  • 2,442 posts
Posted 23 May 2013 - 07:27 PM
The bonnet was left for days and the rear bits have been a week to 10 days min,  only the front end done today and that is fine !!  Very odd,  very frustrating !!
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 23 May 2013 - 09:10 PM
almost the whole van is painted in rustoleum
#8 grahama
grahama
  • 2,442 posts
Posted 23 May 2013 - 09:20 PM
no problems Bungle,  like mine??
#9 crazypainter
crazypainter
  • 218 posts
Posted 25 May 2013 - 05:50 AM
Usually a reaction or a swell with paint is down to a few things, lack of adhesion, incorrect prep or old paint or thinners based paint etc celly that when the new paint is applied to the old paint the thinners in the new paint will start to reverse and release the thinners in the old celly
#10 grahama
grahama
  • 2,442 posts
Posted 25 May 2013 - 11:56 AM
It was a bare metal reprint. No celly on at all, just rust oleum. The crinckling came up immediately on application of paint, but only on very isolated areas. The paint is thinned with thinners, but the previous coat was the same and no problems. The stripes of reaction do lead me to think of a roller or tray problem, have cleaned well for next coat.
The reaction has dried quite hard so will wet and dry smooth and re coat to see if there is any further reaction on the same places.
#11 grahama
grahama
  • 2,442 posts
Posted 26 May 2013 - 12:23 PM
Just an update.
Gave the reacted areas a 400grit rub down and to metal in a couple of spots.  Gave me this
Cleaned the areas and panel wiped then.  Washed the rollers, foam brushes and trays in panel wipe and went for it.  Reaction sorted,  must have been a bit of crud left on either the tray or roller from manufacture. Will need more rubbing down yet to blend the areas in but looking better.
Thanks for your replies as always,
Graham
