Hi,
Hopefully one of you can hit me with some instant and concise knowledge!!
I'm changing my timing chain and sprockets. Which i am not trying to fit. The Haynes manual says the crank and cam woodruff keys shouls be at 12o'c and 2o'c respectively. My crank is at 12 but the cam has the woodruff key at about 7o'cish
I have TDC and confirmed it by seeing 7 - 8 rockers rocking
I'm pretty sure nothing moved while undoing the cam sprocket. Certainly not 180 degrees!
Have I done something wrong? If so what?
I put the new chain on the new sprockets with dots facing. Then I rotated the chain and the cam key groove is pointing to 8o'c, pretty much the same as the cam woodruff key...
So have i simply got TDC on the wrong stroke? If so do I just have to rotate the chain as above to get it back on the right way??
Please help quickly as I don't want to still be in the car park at midnight trying to sort things out!!!
Nearly forgot to add, 1986 city 998
Edited by BVY, 24 May 2013 - 03:30 PM.
