Would This Brake Bias Valve Fit On My Brake Pipe?
16 replies to this topic
#1 ToM 2012
ToM 2012
  • 4,066 posts
Posted 24 May 2013 - 07:06 PM
hi i have been told to get one off these so my front brakes lock up more then the back ones. i have messaged the chap that is selling it and he said....
 I am unsure what fitment the classic mini brake line is? The bias valve is 1/8 NPT, if you could check what the mini brake lines are then I may be able let you know.
this is the item i need. http://www.ebay.co.u...984.m1423.l2649
 thanks tom
#2 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 24 May 2013 - 07:33 PM
This will need to be plumbed in to the line, so cutting, adding new unions and flaring the brake line. You can get the right unions, just make sure it's suitable for your brake line diameter (6mm IIRC) :)
#3 ToM 2012
ToM 2012
  • 4,066 posts
Posted 24 May 2013 - 07:41 PM
shall i tell him its 6mm IIRC? as i dont no what he is asking for. if you was after one would you buy this for yours? thanks tom
#4 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 24 May 2013 - 08:04 PM
I think it's a 6mm diameter brake line, I am not sure. You will need to double check this so I don't cause you any issues!!:P
I would, doesn't look to bad, but I can't see it in hand so I don't really know
#5 ToM 2012
ToM 2012
  • 4,066 posts
Posted 24 May 2013 - 08:24 PM
ok mate cheers. does anyone no the diameter of a brake line? is it 6mm? thanks tom
#6 1984mini25
1984mini25
  • 8,843 posts
Posted 24 May 2013 - 09:06 PM
why do you need the fronts to lock up more?
As surely if you have enough braking force to lock the fronts, any more braking efficiency clearly isn't needed as your exceeding the grip from the tyres anyways.
#7 ToM 2012
ToM 2012
  • 4,066 posts
Posted 24 May 2013 - 09:09 PM
the brakes work fine when driving normal but if i slam the brakes on the back end comes out as the back brakes lock first. so was told to get one of these to fit on so more fluid goes to the front ones first rather then the rear. thanks tom
#8 1984mini25
1984mini25
  • 8,843 posts
Posted 24 May 2013 - 09:10 PM
Try rebleading the fronts and see if that makes a difference.
#9 ToM 2012
ToM 2012
  • 4,066 posts
Posted 24 May 2013 - 09:19 PM
ile give it a try if that does not make a difference would you go for one of those bias valves?
#10 tractor
tractor
  • 662 posts
Posted 24 May 2013 - 10:02 PM
Brake lines are 3/16 of an inch in diameter Tom if that helps
Trac
#11 tractor
tractor
  • 662 posts
Posted 24 May 2013 - 10:04 PM
Also there should be around a 70/30 split where your front brakes do 70% of the braking hence the need for a bias valve
Trac
#12 ToM 2012
ToM 2012
  • 4,066 posts
Posted 24 May 2013 - 10:05 PM
trac will message them that now and see what they say cheers mate.
#13 ToM 2012
ToM 2012
  • 4,066 posts
Posted 24 May 2013 - 10:07 PM
Trac
you ever fitted one to a mini trac?
#14 tractor
tractor
  • 662 posts
Posted 24 May 2013 - 10:15 PM
Trac
I've got a servo set up on my project with its got two lines, one for the front and one for the rear, the system features one of these https://www.google.c...7jAqjizeaJmB-M: it does all the balancing and pressure distribution, it's a later type set up I think completely different to what you've got on your project
Edited by tractor, 24 May 2013 - 10:19 PM.
#15 tractor
tractor
  • 662 posts
Posted 24 May 2013 - 10:24 PM
Here you are mate this listing talks more sense http://www.ebay.co.u...=item4d0ccddb06
What you'll need by the looks of things is 2x male m10 unions that will fit your 3/16 line, should cost you about £3 for 10 of ebay ignor the male to male ones you get free with it
You ever done any brak flaring before? I can take you through it if you want, I've just learnt my self
Trac
Edit here's the unions you'll need http://www.ebay.co.u...=item257bfe3edd
Edited by tractor, 24 May 2013 - 10:29 PM.
