Mk1 Brake Pedals.
Posted 24 May 2013 - 08:49 PM
The car's just had a full restoration and the spec is as follows:
- All new lines
- New remote servo
- New cooper s reservoir
- New rear cylinders
- New rear shoes
- Goodridge hose set
- New pistons & seals in the calipers
- New disks & pads on the front.
The system has been bled 3 times, twice by myself and once by the garage. So my question is, what else do I do?
One thing I have noted is that there were two different pedals for the Mk1, the first being 21A1426 for std cars and 21A1065 for cooper S. As I robbed an 850 deluxe for bits in my restoration, I assume I have 21A1426, could this "wrong" pedal be the source of my problems? If so where the f*** am I going to get a 21A1065 from as they are now obsolete. If my problem is pedal related, would a later pedal box on my mk1 reservoirs work?
Or Could it be the calipers.....
Really hoping someone can point me in the right direction.
Scott
Posted 24 May 2013 - 09:18 PM
Check the master cylinder or possibly the hub/bearings for movement
Edited by pdaykin, 24 May 2013 - 09:19 PM.
Posted 24 May 2013 - 09:23 PM
Posted 24 May 2013 - 09:25 PM
I'm surprised it passed with that amount of pedal travel
pull up hand brake - does that improve it ?
to find the problem I would use a clamp on the flex pipe of each wheel to eliminate it
then by pass the servo if the above don't work
you mention 'New cooper s reservoir' - do you mean new master cyl ?
also check when bleeding - that the pedal returns all the way up - they can stick a fraction from the top
Edited by sledgehammer, 24 May 2013 - 09:29 PM.
Posted 24 May 2013 - 09:30 PM
Posted 24 May 2013 - 11:00 PM
Once you've eliminated wheel bearing slop - you've got shoe adjustment left.
Suggest you park up - get a firm pedal by pumping twice as you have been, leave the car for 10 mins and see if you have to do the same thing again. Don't move the car. If you can then this points to rear shoe adjustment (assuming the MoT tester didn't warn about excessive wheel bearing play).
How on earth the tester allowed an advisory only for brakes you need to pump up to stop is beyond me.
Posted 25 May 2013 - 08:24 AM
Posted 25 May 2013 - 12:37 PM
Will check & feedback.
Posted 25 May 2013 - 02:11 PM
If the bais valve was nearly closed - then that would have caused resistance to flow - so air may still be in the back pipe work
wind it open & re bleed the backs
then set how it should be
still suprised it passed with a low pedal
also try a triple pump - hold down - then release the bleed - always works for me
Edited by sledgehammer, 25 May 2013 - 02:13 PM.
Posted 26 May 2013 - 02:57 PM
Thanks all for your advice.
