Mpi Help Needed Urgent
2 replies to this topic
#1 tommustoe
tommustoe
  • 23 posts
Posted 25 May 2013 - 07:52 AM
hi everyone,
right i have a Rover Mini MPI what has just come out the garage for the full body restoration looks absolutley amazing. Its going for its MOT at the begining of next week but have a slight problem with the front right suspension it seems to be dipping and scraping on the wheel does anyone know what this could be? and would it be worth replacing the whole suspension?
thanks guys
#2 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 25 May 2013 - 08:08 AM
Its worth finding out where the problem is before rushing in and changing out what might be the wrong components. Might be worth taking a few measurements. Is the top of the wheelarch closer to the top of the wheel than the other side? (Wing not attached correctly) Is the subframe base closer to the ground right side when compared to the left? (suspension too low - rubber cone tires; trumpet ball joint worn); Are the wheels & tyres the same size both sides? What ws done to the suspension - have you hi-los? (needs adjustment), does it scrape when going over bumps? (shock absorber) or has there been other suspension work thats not been done correctly, maybe?
Beautiful looking Mini, I'm jealous!
Edited by Blatherskite, 25 May 2013 - 08:09 AM.
#3 tommustoe
tommustoe
  • 23 posts
Posted 25 May 2013 - 08:51 AM
Haha thanks it is look beautiful ;) haha
And okay cheers for the information hopefully going out to the garage today so I take some measurements and have a look
Thanks again
