89' Mayfair 998cc
I've had this mini for quite some time and have finally decided to put it on the road. After all why not have two so you have a choice. I've worked out most of its issues, but still having a few with the wiring. A prior owner has made some changes to the wiring so trying to sort them out is a challenge. I cannot get the Hazards to work, not real sure which way to wire it back into the harness, or if anyone has a bypass solution. Ive read most of the topics on hazard issues, which gave some help. here are the pictures, the blue wire was running all the way across the bulkhead and looked to be connected to the positive on the coil. Gave it a try, didn't produce anything but bad running. The car seems to be missing some in line fuses as well. top one is rear fog, middle is the dip/dim, bottom isn't connected to anything, but everything else is working.
Edited by jmac201, 25 May 2013 - 03:41 PM.
