998 Backfire Through Carb After Headgasket Change
7 replies to this topic
#1 EvanB
EvanB
    Just On Tickover
  • 6 posts
Posted 25 May 2013 - 07:20 PM
My Mini (74 998, HS4 carb) was running rough and overheating so I changed the headgasket. It was burned through between cylinders 1 and 2.
I got it back together last night and adjusted the valves. When I tried to start it it backfires through the carb at idle. I didn't change any settings to the timing or carb while the head was off.
It seems to smooth out a bit when revving but at idle or when letting off the throttle or pressing the throttle it will backfire through the carb. I turned the distributer a bit to see if it made a difference and it smoothed out a bit but still backfires.
Any ideas on where to go from here?
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 25 May 2013 - 07:23 PM
could be an air leak on the manifold.
Or maybe even ht leads on wrong
#3 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2013 - 07:24 PM
Adjust tappet clearance again, check for airleaks at the manifolds, then re-set mixture to 3.0% CO at idle
#4 eeae6000
eeae6000
  • 328 posts
Posted 25 May 2013 - 07:47 PM
timing!!
#5 EvanB
EvanB
    Just On Tickover
  • 6 posts
Posted 25 May 2013 - 08:52 PM
HT leads are on correct. I loosened the valves up a bit thinking maybe the intake valves weren't closing all the way. That didn't help any. I tightened down the manifold a bit more. It seemed like there was a bit of seepage of something on the gasket around the intake runners. I sprayed carb cleaner all around them while it was running and it didn't change anything.
#6 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 25 May 2013 - 09:27 PM
As said before reset tappets.
#7 EvanB
EvanB
    Just On Tickover
  • 6 posts
Posted 25 May 2013 - 10:44 PM
I found the problem. Somehow in my hurry to get it put together I thought the ignition rotor turned clockwise and never thought I could be wrong. I put the wires in the correct order and it runs great now!
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 26 May 2013 - 08:21 AM
:)   happens a lot that's why I suggested it
