Removing Bearings From Hub
2 replies to this topic
#1 snowsports1
snowsports1
  • 68 posts
Posted 25 May 2013 - 08:30 PM
Hi I have completely stripped rear hubs and am unsure how to get the bearings out?
#2 blacktulip
blacktulip
  • 6,231 posts
Posted 25 May 2013 - 09:17 PM
They usually pull out without any trouble. Are they not coming out?
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 May 2013 - 09:18 PM
Remove the seal on the rear of the bearings and knock out the inner races and then with a copper drift carefully drift out the outer races from the hub assembly, there is usually a small slot in the hub to get access to the edge to drift it out. Then drift the new outers into the hub untill fully seated and grease the inner races and pop in with the spacer and replace the oil seal and refit.
Do not use a screw driver the inner races are a high carbon steel content and you could chip the surface or loose a eye from a flying bit.
Edited by KernowCooper, 25 May 2013 - 09:19 PM.
