Removing Front Subframe
Best Answer tiger99 , 30 May 2013 - 12:12 PM
Or undo the rack U bolts and the steering column pinch bolt, and take the rack out with the subframe. Then you have more working space to separate the ball joints. Go to the full post
Posted 29 May 2013 - 03:13 PM
I am having an issue removing the front subframe. I have all the bolts off however I cannot get the steering link off.
I tried to test the tie rod end off but could not get the rod off the
I then tried to get the bolts of the hub, but there is a piece of metal that is stopping getting them undone.
A photo is attached
Any tips?
Posted 29 May 2013 - 03:18 PM
Posted 29 May 2013 - 03:25 PM
Do you mean the split pin?
Posted 29 May 2013 - 03:39 PM
Photos attached
Posted 29 May 2013 - 03:47 PM
You will require a ball joint splitter......and remove noy first then remove washer then refit nut till top of joint is flush with nut slide in ball joint splitter and break joint.........there are 2 types a hammer in http://www.minispare...px|Back to shop
or the best type http://www.minispare...px|Back to shop
the screw in tats this does least damage.......
Posted 29 May 2013 - 03:50 PM
Posted 30 May 2013 - 12:12 PM Best Answer
Posted 30 May 2013 - 05:39 PM
That's what I ended up doing, as I couldn't get the tools for undoing ball joints. Just needed to take the bolt that was holding the steering rod completely out so that it could come out.
