Pro Motive Build In Sunny Scotland
245 replies to this topic
#241 evolone38
evolone38
  • 72 posts
Posted 24 June 2019 - 11:08 PM
Are both bearings shot? You can take the shaft out from the back and then get the nut off. I had that bearing failure about the same driving distance.. I think it is a lack of oil saturation.
No space for more bearings, buy top quality BB and do a oil capacity mod. So much better for me it has been and I am about +4k miles now.
#242 thespikeyone
thespikeyone
  • 237 posts
  • Local Club: none yet
Posted 03 July 2019 - 09:38 PM
Now then.
Managed to get the diff stripped, found this when I took the nut and pinion shaft out.
B4-DD0805-70-F0-42-F1-B18-A-DAF9-B3604-C
needless to say the it looked like a unicorn had taken a dump in the bottom casing with the amount glitter and shiny bits in there!!!
thoroughly inspected the diff, crown and pinion gears and and surprisingly no damage what so ever!!!!! surprising because ball bearings are not known for their soft squidgy nature.
the play in the output shaft is due to worn cover plate bush.
gonna replace, input/output shaft bearings and seals as well as both cover bushes and seals and do the breather mod.
one question about the breather mod, did you just drill and tap it the whole way through the casing or just drill and tap the same depth as the airline fitting then open up the hole under it?  on mine it only looks like a bout a 4/5mm hole in the internal side of the casing.
#243 evolone38
evolone38
  • 72 posts
Posted 04 July 2019 - 06:42 PM
one question about the breather mod, did you just drill and tap it the whole way through the casing or just drill and tap the same depth as the airline fitting then open up the hole under it?  on mine it only looks like a bout a 4/5mm hole in the internal side of the casing....
I went all the way through and tapped it. The pressure is less so it doesn't spit out the top nearly as much and since I run more oil, bearings are doing well. You might as well do the drain plug oil capacity mod while you are at it... makes changing / adding oil so much easier.
#244 thespikeyone
thespikeyone
  • 237 posts
Posted 04 July 2019 - 09:17 PM
And what is this mod exactly, got any pics etc??
#245 evolone38
evolone38
  • 72 posts
Posted 04 July 2019 - 11:52 PM
page 5 of my build log has some info for you.
#246 kubinski
kubinski
  • 11 posts
Posted 07 September 2019 - 08:26 AM
Hello me again :shy:
Do you have some pictures how you have made your throttle cable (from the engine to the pedal)
Where did you drill the holes for the revurse and the shift cable?
Many thanks :highfive:
