looking good mate
Who Wants To See My Willy :)
#76
Posted 09 February 2014 - 07:52 PM
#77
Posted 09 February 2014 - 07:55 PM
#78
Posted 13 February 2014 - 07:37 PM
ok did abit of head work today , "cylinder head" before you ask.......... flowed and smoothed out the throats , , ,,, i probally could of done abit more but im not spending another day behind the die grinder !!, i then pressed in the bullet nose bronze valve guides and reamed them out , , i then cut the seats with a 3 angle cutter but didnt go down to the 30 degree as not to sure how much to sink the valves at the moment, the valves are 36 inlet and 32 exhaust, , , next with the head, using the valve seat cutter, im going to cut a radius around the exhaust valve to de shroud it up to the headgasket, and maybe the same with the inlet depending on room , more updates soon byee
Edited by medicalgradenitrous, 13 February 2014 - 07:38 PM.
#79
Posted 14 February 2014 - 11:32 AM
Good Work!!
#80
Posted 20 February 2014 - 08:44 PM
nawww look at you finding ya feet in the work shop ;)
#81
Posted 23 February 2014 - 08:59 PM
some more goodies ready for the engine build ,The full engine spec is to be : A+ block 1293cc, omega cast pistons 10cc dish, lightened and balanced A+ rods, ARP rod Bolts, Metro Turbo 6581 crank, steel center strap, lightened verto flywheel, RTS Clutch, Turbo oil pump, MG Metro cam, MED 1.5 ratio roller rockers, mg inlet valves 36mm, stainless 32mm exhaust valves, bronze bullet nosed guides, twin turbo springs, 3 stage seats, opened up combustion chambers, enlarged throats and ports, T3 turbo, pajero intercooler with fan, standard metro turbo carb, big bore down pipe, single motorbike can silencer, straight cut drop gears, x pin diff, center oil pickup, gearbox swarf trap, quick shift, metro oil cooler, megajolt, wideband a/f ratio gauge. im hoping for 150 bhp , i still need to figure out what final drive i will be using as its primarily a track car , and on 13 inch wheels any suggestions ? cheers guys
#83
Posted 04 March 2014 - 08:18 PM
Slacking.......
#84
Posted 10 March 2014 - 09:05 AM
this shell if now for sale if anyone is interested £250
#85
Posted 19 September 2014 - 01:36 PM
#87
Posted 26 September 2014 - 09:21 AM
ha ha, 'Skiddy' LOL
#88
Posted 16 August 2017 - 11:28 AM
Hi,
thinking of doing a similar conversion to one of my minis, any more photos of the vehicle?
