Real quick and easy one for you all.
My build is approaching completion (once I build the front enclosures) and I'm still torn about the last detail, namely whether to run active or not.
The set up is as follows:
DEH 80PRS
Genny sub @ 2ohm into a JL 10w6
Genny P4 @ 4ohm into Genny 16.03
Initially I was just going to chuck them in with the X-overs and bridge the P4 for a healthy 180w per channel.
But now I'm considering either running all 4 output channels separating the mids and tweets or as I've read (on here I think) running the mids bridged still and powering the tweeters off the HU amp, which is supposedly more than sufficient to keep them balanced.
So the options are:
HU -> P4 (bridged) -> passive x-over -> mids/tweets
HU -> P4 -> mids
-> tweeters
HU -> P4 (bridged) -> mids
-> tweeters
What say you learned chaps?
Cheerios,
