1973 Bullnose Reverse Switch
Posted 17 June 2013 - 02:57 PM
Posted 17 June 2013 - 03:03 PM
The switch works on the remote housing where the gear stick is, there is a wire in and out which is 12v back to the mk4 lights, what gear change do you have ? the rod type has the switch but the earlier alloy remote not sure they had one and the switch may well have been a manual on/off switch.
Posted 17 June 2013 - 05:53 PM
Posted 17 June 2013 - 06:16 PM
Then on the rod change the switch is in the side of the allow housing where the geal lever fits, its a switched 12v feed back to the lights and the rear reverse lights earth on the mounting bolts as you describe with the others
Edited by KernowCooper, 17 June 2013 - 06:17 PM.
Posted 17 June 2013 - 06:20 PM
