Every time I start the car up, the engine runs at very high idle. I have done the following.
Changed plug leads, although they don't work using Mr Haynes 1234 wiring layout.
Cleaned plugs
Ultrasonically cleaned injectors and had new filters and o rings fitted.
Cleaned map sensor
Cleaned throttle body and pipes
Cleaned and fitted new o rings to IACV ( I now have spares of these minimum order was 10, also spare filter to throttle body o ring 65mm)
New air filer
New Inlet manifold air temp sensor
New water temp sensor
Still not running right but much better. When I can get it warm I will do stepper motor adjustment.
But it wont start now. Me suspects engine earth as starter motor just clicks. So will do engine steady bushes and earth strap tomorrow. Battery only just recharged. But will put it on charge overnight anyway. Does anyone have a better solution for all those leads bolted together on the solenoid. That is a very weak suspect area, there are 5 leads on here. Must get new bronze nut for that. Most places only sell one with new starter motor. Any idea on the size of thread.
Thanks for reading the witterings of a frustrated MPI owner.
Edited by zony, 17 June 2013 - 04:18 PM.
