I have a 94 sprite SPI and bought it knowing that it was over fuelling. now I have stopped the fuel issue I have now got to sort out the terrible idle.
the car runs smooth and without any problems. starts first turn of the key cold or hot, but when you blip the accelerator the engine sticks at the rpm you reached for a duration between 1-10 seconds. the accelerator cable is not at fault as when I rev the engine I use the bar on the inlet. I know there isn't any air leaks as I have had the car connected to a diagnostic machine.
since I have purchased the car I have changed the following:
vacuum hose from ecu to fuel trap
vacuum hose from fuel trap to inlet manifold
lambda sensor
new exhaust manifold
manifold gasket
inlet manifold locating rings
new K&N air filter
new spark plugs
I have also blocked of the port under the fuel lines as when I purchased the car there was no hose. I was told to do this by a mini mechanic as this is what he does on there race cars.
(above picture of blocked off port)
the breather rail on my car that connects a hose from the front of the inlet manifold and fuel purge valve is a little rusty (as shown bellow)
I have read some other topics to see if I could address this matter. the only thing I came across is the throttle position sensor. I tried testing this today. as mentioned in another topic I unplugged the sensor when the car was idling erratically to see if the revs would drop down but this only increased them. if I am honest when the engine picked up revs I plugged it back in again as it worried me. this brought the revs back to the sticking point and then they dropped down to idle.
I am still unsure on the condition of the sensor. I'm not even sure if this is the problem.
My MOT has now run out and I would like to get this sorted before booking the car in. if anyone could shed some light onto this is would be much appreciated.
