Rear Always Hits Top Of Arche
6 replies to this topic
#1 mjpuds
mjpuds
  • 337 posts
Posted 17 June 2013 - 07:34 PM
As mentioned what ever height I seem to put my rear h/l at it always seems to hit arches new dampers fitted . Could the cone be worn out...what effect would this have?
#2 jaydee
jaydee
  • 8,565 posts
Posted 17 June 2013 - 08:16 PM
You sure its not rubbing on the dampers?
#3 Tupers
Tupers
  • 4,173 posts
Posted 17 June 2013 - 08:53 PM
When is it hitting? Under hard cornering, with lots of weight in the back, when going over speed bumps/pot holes?
Also what width wheel are you running? You may find if you have anything over 6" that they will scuff on the inner arch where it dips down on the outside to meet the body.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 June 2013 - 08:54 PM
how old are your suspension cones ?
#5 mjpuds
mjpuds
  • 337 posts
Posted 18 June 2013 - 12:26 AM
two sides both have same space . tyre is hitting arch.. i can see mark..as for cone not to sure odd i know but i have two sorts of hi los on the back ..as in the pole but the rubber cones ..hmm would the cone make this happen ?
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 18 June 2013 - 06:45 AM
replace the cones if you don't know how old they are
#7 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 18 June 2013 - 09:50 AM
It's either your cones or your dampers mate, if, mine was doing exactly the same so I took the hit and renewed the whole suspention on the car because it seriously needs doing,
Check your dampers for leaking
