Sequence And Torque For Tightening Up Head?
6 replies to this topic
#1 crf150
crf150
  • 555 posts
Posted 17 June 2013 - 08:30 PM
I've had the head skimmed and vaves re seated, have a new head gasket but I was wondering in what order you have to tighten the nuts up to seal the gasket properly? I got told its crossing over from stud to stud, is that right? Also what torque should they be tightened at? Thanks
#2 jaydee
jaydee
  • 8,565 posts
Posted 17 June 2013 - 08:35 PM
spiral from the centre nut, torque at 45N then again in spiral pattern to 55N then again in spiral pattern to 65N
Warm up the engine, fill up the fluids and check for leaks.
Retorque after a few heat cycles if using a copper gasket
Feel free to ask
#3 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 17 June 2013 - 08:39 PM
page 64 in this doc
http://www.uscars.bi...CD_wmxn990e.pdf
then set the valve clearances, run the engine, then loosen each nut in turn and then re-torque, one at a time in the correct sequence
#4 jaydee
jaydee
  • 8,565 posts
Posted 17 June 2013 - 08:42 PM
#5 crf150
crf150
  • 555 posts
Posted 17 June 2013 - 08:55 PM
Thanks, can't run the engine yet as the engine us out of the car :)
#6 crf150
crf150
  • 555 posts
Posted 17 June 2013 - 09:00 PM
So is it 65Nm total torque?
#7 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 17 June 2013 - 09:08 PM
68nm total, so on the final torque down set the wrench to 68nm
