So I saw some cars at L2b with these on.
As my exhaust hangs pretty low (catalytic converter scrapes sometimes), will one of these pull it up a bit? And where can I get one?
Thanks.
Edited by anthonysjb, 17 June 2013 - 08:31 PM.
Posted 17 June 2013 - 08:30 PM
Thanks.
Posted 17 June 2013 - 08:49 PM
it's the old way mini exhausts fitted
a cotton real rubber mount bolts to the subframe, a small bit of metal hangs off this and that clamp you can see hangs from the bit of metal
Posted 17 June 2013 - 08:55 PM
Posted 18 June 2013 - 11:03 PM
Make sure you get a new gearbox mount on ASAP if you are using you mini at the moment! I had the same problem and me brand new Maniflow manifold snapped in half!!
