Tyres
13 replies to this topic
#1 MattMiniS96
MattMiniS96
    Half pint guy in a half pint car
  • 196 posts
Posted 18 June 2013 - 02:16 PM
What are the best road tyres for a mini on 10's?
Also would Yoko AO32's good for road use?
I like.the pattern, sad I know...
thanks in advance :)'
#2 jaydee
jaydee
  • 8,565 posts
Posted 18 June 2013 - 02:17 PM
They're excellent tyres
Will wear faster than A008s so if yours a daily, just consider this
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 18 June 2013 - 02:36 PM
Personally I prefer the falken over the A008 for an everyday tyre, many will disagree... but for outright grip and performance then the 32R is the one to go for.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 June 2013 - 03:13 PM
I run Falken 165/70-10s and there not a bad tyre as mine never see's a wet road I can't comment on what thats like.
#5 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 18 June 2013 - 03:20 PM
I run 165-70-10 falkens on my minis and have had no issues with them in the wet or dry.
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 18 June 2013 - 04:46 PM
no issues using the new type 12" falkens, car was used daily all last year inc winter.
#7 Jmccrary
Jmccrary
  • 171 posts
Posted 18 June 2013 - 06:24 PM
I go for falkens...been running them for about 14 years on various motors
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 June 2013 - 07:32 PM
  Having just replaced another set of A032-Rs I must say the wear rate of these tyres is fine.  People always say they wear fast but the rears I just got rid of were replaced because they were too old and cracked, not because they were worn.  The fronts were worn, but they were the pair I bought at the IMM for Mini 50 so not exactly young.  This car is a daily, and (until the baby came along) used to regularly go on long trips including the BH2N and has put on many laps over there.  I've been using these more or less since they were introduced sometime around 2002 and I think the ones I just put on are set number 4 at the front, the rears last longer.  The first set I fitted wore out in no time, but I found it was due to a slight setup issue with the tracking and camber which had changed more than I anticipated with ride height.  If the car is setup right, these will last around 3 years at the front and 4-5 at the rear but they are very sensitive to setup.
#9 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 18 June 2013 - 07:35 PM
more important to make sure the mini is square and drives properly, then tyres last had some a008's that had 4.5mm left after 15,000 miles inc a couple of track days
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 18 June 2013 - 08:43 PM
That's the crux of it... if you run -ve camber or a little toe in/out then they will wear very quickly...
oh, and if you go to santa pod, expect to write off a set in a weekend.... :-o
#11 valve bounce
valve bounce
  • 694 posts
Posted 18 June 2013 - 09:09 PM
i had a full set of a008 on mine and i swapped them around so they wore of even, they did about 13,000ish miles.
the 32's are the best for grip but mine only lasted 1000 miles on the front but in that there was 3 hillclimbs 3 autotests. normal driving should see 3000miles on the front and 6000 on the back i reckon
not really a fan of the falken, there ok but not as good as the a008
#12 Jmccrary
Jmccrary
  • 171 posts
Posted 18 June 2013 - 10:54 PM
I must know...what is santa pod?
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 June 2013 - 11:36 PM
Santa Pod is a raceway where you race cars/bikes over a 1/4 mile to see who can cover the distance the fastest
#14 MattMiniS96
MattMiniS96
  • 196 posts
Posted 19 June 2013 - 03:21 AM
Wow, thanks for all the info guys!
I was thinking about running a but of -ve camber but I definitely take it all into consideration (he says after already getting the garage to order and fit them)
I think if they do wear more quick, ill do what valve bounce says and swap them around...
