Sound System Draining Battery
8 replies to this topic
#1 Chris1992
Chris1992
  • 2,022 posts
Posted 18 June 2013 - 09:12 PM
hi guys, so heres my problem
about a week ago i realised that something is draining my battery, and i couldnt figure out what it was. i recently discovered that my amps (or something associated with them) are causing the problem.
when i touch the cable from my amps to the battery terminal there is a spark, even though the amps and stereo are off.
im running a sony stereo with two front speakers connected directly to it. ive then got two amps mounted in the boot, one of which is powering the two 6x9s in the rear shelf, and the other is powering the 1800w sub.
i mentioned this in another thread i started, but thought i should set one up in the proper section.
hope someone can help me
cheers
#2 ToM 2012
ToM 2012
  • 4,066 posts
Posted 18 June 2013 - 09:19 PM
its probably the second amp that is draining it i have a subwoofer in mine with a built in amp that has live power going to it constant but mine doesnt drain i also have 6x9 speakers and i am just running speaker wires to it. take the amp out thats being used for the 6x9 as you dont need it. or you could put your wires from the 6x9 into the sub amp if that amp is powerfull enough to power all 3.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 June 2013 - 09:40 PM
Put a clamp type amp meteron the battery positive cable which measues DC amps and take a reading and then disconnect the amps and see which is drawing the power
Edited by KernowCooper, 18 June 2013 - 09:41 PM.
#4 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 19 June 2013 - 12:28 AM
Good advice but worth reminding the OP that a normal cheap AC clamp meter may not read DC amps.
Edited by Captain Mainwaring, 19 June 2013 - 12:28 AM.
#5 Chris1992
Chris1992
  • 2,022 posts
Posted 19 June 2013 - 12:35 AM
ok thanks for the advise guys, ill have a go at that when i can get hold of an amp meter. should also probably point out that i know pretty much bugger all when it comes to electronics lol
i probably should have checked this before i taped up the wires and put my sound deadening, carpets and seats in :mmkay:
#6 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 19 June 2013 - 06:44 AM
Have you correctly wired the amp to the remote switch on cable from the headunit?
Have you also wired the switched ignition live correctly to the headunit?
If either of these are wired to a permanent live your system wont be full off ever.
#7 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 19 June 2013 - 06:45 AM
Also you don't say if this happens over night or when you are actually driving?
#8 Chris1992
Chris1992
  • 2,022 posts
Posted 19 June 2013 - 11:47 AM
ok thanks mate, ill check that. im off to le mans tomorow though so it will probably have to wait till after but ill update when i can.
the cars not actually been driven yet. ive just finished a 3 year restoration and only got it running a few days ago. basically, if i left the amps connected to a fully charged battery overnight, it would be completely dead the next morning.
#9 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 19 June 2013 - 05:13 PM
Ok so somethings not switching off correctly.
As I said make sure your headunit has the switched live and the correct remote switch cable is connected to the amps.
