Spark Plug Recommendations?
6 replies to this topic
#1 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 19 June 2013 - 10:36 AM
Close to getting my engine build finished and time to think about plugs........
What would you recommend for a fast road 1380 (286, 10:1, Aldon dizzy & coil) and should I use something slightly cooler for the initial running in with a hot set for later use?
Thanks,
Bob
#2 jaydee
jaydee
  • 8,565 posts
Posted 19 June 2013 - 10:50 AM
you'll get many diffrent opinions on this
id try the BP6ES, i run them with a 11:1 CR so at a guess they should be fine, the 7s are for very hot combustion and sound like marmite, some swear by them others wouldnt touch them with a bare pole
the 7s are cheaper anyway so you can try them if you want, and if they get fouled or missfire bin them
Edited by jaydee, 19 June 2013 - 10:50 AM.
#3 Old Bob
Old Bob
  • 825 posts
Posted 19 June 2013 - 01:16 PM
Thanks JD
Bob
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 June 2013 - 04:51 PM
I have a similar spec to yours and run NGK BP7s or Champion N7Ys
#5 racingbob
racingbob
  • 3,061 posts
Posted 19 June 2013 - 05:04 PM
I got 7's in mine they seem good
no bad comments when on dyno
I only use bp or shell 98
#6 Old Bob
Old Bob
  • 825 posts
Posted 19 June 2013 - 05:49 PM
Thanks Guys - Same plugs for initial run-in and later road use?
Bob
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 June 2013 - 07:36 PM
Yes mate put mine in from the word go never had any problems --- BUT you need to be aware that if your mixture is on the rich side the colder running plug (7s) may not run hot enough to burn the deposits off and a misfire will be the result. So if you setup is correct and mixture is in the ballpark then you wont have a issue. Just something worth pointing out.
And please anybody reading this who has a rich mixture PLEASE DONT THINK BY RUNNING HOTTER PLUGS WILL SORT IT, I dont want people showing me pistons with holes in and cars that run on when shut off. ^_^
Edited by KernowCooper, 19 June 2013 - 07:39 PM.
