Spi Not Starting......again :(
15 replies to this topic
#1 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 19 June 2013 - 10:59 AM
Once again, my car is on its time of the month and has decided it does not want to start. Turns over fine with plenty speed, spark present, fuel present, however, still will not start. Any ideas what to do? Car is a 1995 Spi. Diagnostic has been plugged in and annoyingly, all seems normal. VAC lines are all in check. Help?
#2 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 19 June 2013 - 11:05 AM
well if there's sparks and fuel then all that's missing is air!! but unless the air filter is completely blocked then unlikely that. Perhaps the spark isn't happening at the right time - crank sensor?
#3 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 19 June 2013 - 11:15 AM
As said above take the air filter off and try?
#4 crazypainter
crazypainter
  • 218 posts
Posted 19 June 2013 - 11:53 AM
they have a problem with the fuel pump live dropping out if that helps
#5 IainStallard
IainStallard
  • 1,114 posts
Posted 19 June 2013 - 12:15 PM
Air filter off and tried to start it but nothing still. Fuel pump is all good. Will clean the crank sensor tonight to see if that makes a difference
#6 IainStallard
IainStallard
  • 1,114 posts
Posted 19 June 2013 - 08:53 PM
Running again now! But for how long? Managed to get it going by jump starting it and after constant turning over and a lot of coughing, it fired into life! However, I am thinking that something is amiss. Any ideas people?
#7 Moggyton
Moggyton
  • 1,152 posts
Posted 19 June 2013 - 09:50 PM
Maybe your battery is on its way out and isnt holding a good enough charge to fire the engine
#8 IainStallard
IainStallard
  • 1,114 posts
Posted 19 June 2013 - 09:55 PM
Battery seems fine, turned over fast enough. Only jump started it because I had worn the battery down from trying to start it so much
#9 hunterg30
hunterg30
  • 349 posts
Posted 19 June 2013 - 10:13 PM
coolant temp sensor?
#10 IainStallard
IainStallard
  • 1,114 posts
Posted 19 June 2013 - 10:22 PM
Temperature gauge moves as normal so seems ok
#11 hunterg30
hunterg30
  • 349 posts
Posted 20 June 2013 - 09:51 PM
check all the water ways in the intake manifold are clear, also plug the diagnostic machine back in when the engine is cold and see what temp readings it shows.
i had a similar prob and it was the temp sensor not working properly,the ecu was not reading the engine was cold so it did not alow for this when trying to start
#12 IainStallard
IainStallard
  • 1,114 posts
Posted 20 June 2013 - 10:25 PM
All sensors seem ok, coolamnt temp and air temp seem as normal.
Car starting easily on the key now but it seems rather under powered :/ however, that might just be me coming from my TVR at the weekend
#13 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 20 June 2013 - 10:27 PM
Seems stupid, but is there a possibility you may have flooded it?
#14 zony
zony
  • 165 posts
  • Local Club: Welsh Rarebit Mini Club
Posted 20 June 2013 - 11:17 PM
The sensors are weird beasties. They may seem ok, but there is only one way to check, stick it on a diagnostic tester and read the live data. Also check earth straps in the engine bay and the boot and ensure they are spotless, lubricate with copper grease.
You can't just assume that it seems ok.
#15 IainStallard
IainStallard
  • 1,114 posts
Posted 21 June 2013 - 06:56 AM
I have been reading all the live data on the diagnostic and all seems correct to the conditions outside
