Horrible Noise Driving Me Crazy!
Best Answer KernowCooper , 19 June 2013 - 07:42 PM
Have you checked the bush at the bottom of the Knuckle in the top arm ?
Go to the full post
25 replies to this topic
#1 yellowmini80
yellowmini80
  • 20 posts
Posted 19 June 2013 - 01:16 PM
whenever i am driving i get a horrible cracking/creaking noise coming from either my front subframe or suspension etc. im absolutly puzzled to what it could be.
When i am on my own it does it over any little imperfection in the road.... When i have a passenger adding weight to the other side the noise goes away and it behaves.
Link to video i took of the awful sound -
thanks in advance to any replies
#2 jaydee
jaydee
  • 8,565 posts
Posted 19 June 2013 - 01:59 PM
Check subframe bushes, sounds like one of them is completely shot.
#3 yellowmini80
yellowmini80
  • 20 posts
Posted 19 June 2013 - 02:21 PM
car was only rebuilt last year with all poly bushes for the front end... could this still be a possibility?
#4 jaydee
jaydee
  • 8,565 posts
Posted 19 June 2013 - 07:08 PM
I'd first replace the poly bushes with something better (either rubber all round or solid moutings are the best options) and hope they havent cracked anything
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 June 2013 - 07:11 PM
check around the engine mounts, subframe mounts and stabilizer mounts for cracks in the body
#6 bluffin
bluffin
  • 234 posts
Posted 19 June 2013 - 07:24 PM
Spray all your poly bushes with GT85, you can get it from Halfrauds, when you installed them did you use any grease? I usually use White Lithium bike grease :)
#7 jaydee
jaydee
  • 8,565 posts
Posted 19 June 2013 - 07:28 PM
So they can move around even better
Why are they still selling poly bushes.....
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 June 2013 - 07:38 PM
they come in bright colours and make your car faster
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 June 2013 - 07:42 PM   Best Answer
#10 yellowmini80
yellowmini80
  • 20 posts
Posted 20 June 2013 - 07:42 AM
Thanks for the replies guys. I will get a load of grease around all of the bushes and if this solves it then i will get a new set of front end bushes/mounts
#11 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 20 June 2013 - 09:07 AM
This is interesting!
I chased a similar noise around for a year. Replaced bearings, front tie rubbers, brakes in bits 4/5 times, bought a CV joint and was ready to replace that...
Then I thought it was the alternator bearings, they were noisy , but not my issue. I then changed the rubber subframe mounts to solid and noise GONE!!!!!!
#12 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 20 June 2013 - 10:36 AM
Yep, without opening a can of worms about cheap spares - if the bushes are too hard then they'll end up just deforming, leaving slack for nasty noises.
#13 yellowmini80
yellowmini80
  • 20 posts
Posted 20 June 2013 - 11:46 AM
true, i dont think ive bought anything for it yet that hasnt turned out to be cheap chinese crap. The track rod end rubbers had perished before it was even on the road! going outside to grease up the rear subframe mounts and front mounts now, will see if this makes any difference *fingers crossed*
#14 yellowmini80
yellowmini80
  • 20 posts
Posted 20 June 2013 - 12:28 PM
might i add with how much i have lowered it, it is riding on the bump stops... could this produce this kind of noise?
#15 jaydee
jaydee
  • 8,565 posts
Posted 20 June 2013 - 12:30 PM
Could be, leave a minimum 1/2"to 1" clearance between bump stop and top arm
