The rust was worse than I last thought in the above post and is going to take a fair bit more work and I would appreciate anyone's input on how to proceed forward with this.
Here is the damage so far ,
Now It seems that the lovely previous owner has decided to replace the floor to wheel arch bracket directly over some very questionable metal and then just fill the other side.
So far I have worked out I need to replace this bracket , and the corner of the boot floor , although it is solid all the way around the other side.
Is it going to be best to remove the subframe then cut out the rusted metal leaving the floor to wheel arch bracket in place as a alignment aid for the replacement boot floor, then once this is welded in to replace the floor to wheel arch bracket and also the rear closing panel bracket? I plan to fabricate a small repair panel for the wheel arch as the rest of it is solid luckily.
Does the above sound reasonable?
Also is it possible to do without removing the rear valance?
Thanks for any aid and assistance.
Edited by tino, 16 October 2015 - 07:23 PM.
