Hi folks, hope you don't mind me trying to get some answers for my machine on here, but the Metro forums tend to be a bit quiet and I know how much expertise there is on TMF so....
1990 MG Metro 1275, totally standard.
I'm having difficulty engaging gear, mostly on first and reverse. When the engine is hot it nearly always crunches going into reverse. Idle speed is nice and low and I'm pushing the clutch pedal right into the carpet. I'm wondering if the clutch is properly disengaging, the throw-out adjustment is correct, but I'm not sure what else I can check. The main difference from the Mini is that I have a clutch cable, not a hydraulic system. Last winter the cable snapped and I replaced it with a new 'self adjusting' cable. A mechanic suggested to me that the cable's don't always self adjust, but offered no further information (because I didn't ask, as at the time there wasn't a problem). The Haynes manual says that I should dismantle the pedal box, but doesn't say why or what I should be checking or what I might need to replace, so I'm in no rush to do that having had experience with things like clevis pins before.
So, any of you nice people have an idea of what I need to do next? Would be much appreciated.
Huw
