Dinitrol V Por15
12 replies to this topic
#1 golly
golly
  • 251 posts
  • Local Club: MiniForce
Posted 07 July 2013 - 12:26 PM
Has anyone used either of the above rust killers? If so which one is best and has anyone has a positive result?
#2 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 07 July 2013 - 03:31 PM
My dad swears by POR15 on the Healey Sprite and frogeye he restored. Been 4 years since the first one was finished, its still perfect. Not been touched since. Admittedley it lives in a garage, and is only driven in summer.
#3 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 07 July 2013 - 03:33 PM
Does POR15 have a rust killer in their range?
I have used the metal ready and rust prevention paint; but have never seen a rust killer?
Post a link of the product.
#4 l_jonez
l_jonez
  • 1,453 posts
Posted 07 July 2013 - 06:56 PM
Isn't the por15 metal ready a rust treatment?
#5 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 07 July 2013 - 07:44 PM
It just puts a zinc coating on the bare metal. I have tried it on surface rust and it does not remove it.
It says it does but it does not; on the Frost site "It is the ultimate in the relentless fight against rust. It not only dissolves away the rust it also etch primes the clean surface and leaves a Zinc Phosphate coating to prevent further rusting."
Edited by Wise Old Elf, 07 July 2013 - 07:47 PM.
#6 alicetheauto
alicetheauto
  • 1,222 posts
Posted 08 July 2013 - 08:22 PM
At the end of the day, the only way to get rid of rust is with a grinder. Cut out, weld new steel in, plenty of POR 15 on the new bare metal.
#7 mike.
mike.
  • 6,176 posts
Posted 08 July 2013 - 09:26 PM
I used POR15 on mine and thought it was great. Effort to apply though and expensive, but the finish was quality and it really does leave a rock hard protective coating. Very hard to scratch or chip off.
Wear gloves if you use it. If you get it on your skin, you have to wait until your skin dies and falls off :/
#8 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 09 July 2013 - 05:11 PM
Yes I discovered this too late. I could scrub most of the paint from my hands but up my arms was there for weeks.
#9 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 09 July 2013 - 09:18 PM
Is por15 a pain to apply to un corroded steel or new steel? I heard it can be
#10 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 09 July 2013 - 09:32 PM
I've used most things, actually, pretty much every chemical rust remover/converter blahblahblah and the only one that actually works and is pure quality is all of the bilt-hamber lab products. They are phenomenal. I had a bit of fairly thin gauge steel that had surface rust, I put the hydrate-80 on it and just left it on the side of our workshop. Randomly dunking it in water over a period of weeks/months
No real change. I found my winner
#11 mike.
mike.
  • 6,176 posts
Posted 09 July 2013 - 10:42 PM
Hydrate 80 is also the best rust converter i've used, their deox gel is also really good if your items are suitable for treating with it.
But if your applying POR15 you'll need to go back to metal anyway really, in which case you can grind any surface rust off and won't need a rust converter product.
#12 l_jonez
l_jonez
  • 1,453 posts
Posted 10 July 2013 - 04:52 PM
Hmmmm thats strange. I've been using the metal ready for a few years now and I've never had a problem with it not removing surface rust :-/
Just out of curiosity I stripped a old door skin and give it one light coat of metal ready then left it out in the garden over winter
Here's what it looked like after 3-4 months
#13 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 10 July 2013 - 04:57 PM
I wish it did that for me. I sprayed it on my inner wing and then washed off as per the instructions. It did nothing to the rust just put a light coat of zinc over it.  :lol:
