Look What I Won
#31
Posted 28 July 2013 - 10:19 AM
#33
Posted 28 July 2013 - 07:14 PM
#34
Posted 28 July 2013 - 07:15 PM
I'm so jealous, I need some of these so I can get rid of my godawful 13s. Why does nobody make nice 13s?
Have a look on the mini wheel dictionary for some inspiration
Rhys
#35
Posted 29 July 2013 - 12:07 AM
That my friend is an Arc Reactor, check out iron man
#36
Posted 30 July 2013 - 06:29 AM
How did I not see that .....
#37
Posted 24 November 2017 - 10:46 AM
I know this is an old post so hopefully stretch tech or littlemissmagic found what wheel nuts fit these wheels.
I have some standard 60deg nuts but am not happy with the amount of contact area.
Does anybody know the overall diameter of the large seat 60deg nuts from minispares CN5.
Below is the dimensions of the steel insert on the wheel.
If anybody is looking for center caps for these C-21A1962 fit perfect.
Posted 14 December 2017 - 06:19 PM
Pulling up a very old thread here because I have just got a set of these 12" Jupiter wheels and am looking for wheel nuts. The nut shape should be simular to a Rover nut for 12" Rover alloys but the shaft on the Rover nut is 16.5mm and the Jupiter hole is 9/16".
The best fit I can find so far is from Minispares which is 60 deg but has no shaft
I have attached a cross section of the wheel insert.
Posted 14 December 2017 - 07:44 PM
most likely off a different car like a Hillman Imp. they used 7/16" rather than 3/8" studs
#40
Posted 14 December 2017 - 08:39 PM
Posted 16 December 2017 - 02:09 PM
When I got the wheels they were black and silver but didn't suit the car so I changed them to all silver. I got C-21A1962 center caps from minispares that fit perfectly ( IIRR the center hole is 67mm).
Can anybody with 12" Jupiters confirm the size of there stud holes.
Posted 04 August 2018 - 08:11 PM
Desperately trying to find out the offset of the 10 inch version, anyone know??
#43
Posted 04 August 2018 - 08:19 PM
fit under old skool GP5s with discs. and 165/70 10 Yokos
#44
Posted 05 August 2018 - 12:24 PM
Thanks, I found the the back-space in mm on an old eBay auction, for those interested the full wheel spec is 5Jx10 ET16
Edited by joekenton, 05 August 2018 - 12:25 PM.
