4AG power rear drive mini
Posted 07 May 2006 - 11:46 PM
Thought I would share. Been working on this car off and on for 3 years. It is a tubeframe rear drive mini hot rod.
Body is fabricated in steel.
Motor is a turbo charged Toyota 4AG putting out 320hp on the engine dyno. Motor is fully built (rods, crank, pistons, dry sump, Formula Atlantiic head etc.) It is driving the rear wheel via a live axle (Chev 8.8) on a 4 link and pannard. Front suspension is fabricated A arms with coil overs at all 4 corners. Just got the car out of the paint shop. Will start to put together. I will add pictures as it goes together.
Posted 07 May 2006 - 11:56 PM
Posted 08 May 2006 - 12:03 AM
The body including arches is in steel.
Choose the 4AG as it is fully developed thanks to the Formula Atlantic series here in North America. No problem to get 275 hp reliable wheel hp with a turbo and an aftermarket FI system.
Posted 08 May 2006 - 12:45 AM
and do put up progress pics as you go along i think this one will create alot of interest, and are you doing it yourself? or just helping?
wayne
Posted 08 May 2006 - 12:56 AM
I am interested to know since im looking at sticking a 4A-GE into a mini myself. do you have any pics of the RWD setup installed?
Dave
Posted 08 May 2006 - 02:21 AM
how come you didnt consider the 4A-GZE? and is this the 20v Blacktop?
Dave
Hi,
I started with the 4AGZE block, rods and crank as they are all stronger. The 20 valve has a similar block but the internals are different. They are lighter, thus unable to take on the big boost. Better to go with a 7 rib (AE 92) or gz block and internals. I am using the 4 throttle bodies from a silver top for the induction. had to fab up an adaptor to make them work.
Will post pics of the drive line shortly.
Posted 08 May 2006 - 05:44 AM
I bet that thing will be fun to drive when ever u get it on the road
Posted 08 May 2006 - 03:42 PM
Posted 08 May 2006 - 04:28 PM
you dont like cars to be small over there do you ?
Posted 17 May 2006 - 09:46 PM
Posted 18 May 2006 - 06:53 AM
Posted 25 July 2006 - 08:54 PM
Posted 25 July 2006 - 09:03 PM
Posted 26 July 2006 - 02:58 PM
now it might just be the pic but the arches looking a bit photoshopped to me
hmmmmmm........agree
Posted 26 July 2006 - 03:12 PM
