There can be a problem where the Ignition light stays on after fitting a different Alternator
This is due to a mix up when connecting the wiring, the terminals are marked.
B+ Main battery feed.
D+ Warning light
W Phase terminal (12 volt output)
The mistake made is connecting the warning light to the W terminal not the D+ as it
should be, this mistake causes the warning light to stay on.
