:wales: I've got solid mounts on the front subframe and spax coilovers, I'm runnning a 1293 with adjustable boost so was thinking solid mounts as the rubber ones would tear (I feel) any advice? :erm: :erm: :erm:
What mounts?
redmini
, Jun 14 2004 10:54 PM
5 replies to this topic
Posted 14 June 2004 - 10:54 PM
Posted 14 June 2004 - 11:01 PM
I suppose if you dont mind the bone shaking ride then the only thing stopping you is the condition of the floor where they mount. When i fitted them i was advised to put a thick steel plate on the inside so that the floor was sandwhiched between the mount and the plate and therefor spreading the load a bit more and putting less stress in one area.
Posted 15 June 2004 - 07:47 AM
I use solid floor mounts and deflex bushes else where. Also have you got some extra engine steadies ?
Phil.
Phil.
Posted 15 June 2004 - 10:21 AM
:wales: I will have when I make them, I've got deflex on the tie rods and re-enforced the floor mounts as Philster has done but it's the engine mounts I'm not sure about. The only ones I've seen are the deflex quick release and I didn't fancy them, it's only a pin going through the mount that takes all the stresses.
Posted 25 June 2004 - 01:20 PM
I've always used standard engine mounts from the engine to subframe with no probs. Just add all the extra steadies you can, that way the engine will hardly move.
Phil. :grin:
Phil. :grin:
Posted 26 June 2004 - 01:18 AM
:wales: Cheers, I made solid engine steadies today and they fitted nicely, tomorrow I'll have another look to see where it's possible to mount some more.
