Spark Plugs.
Best Answer KernowCooper , 17 August 2013 - 12:00 AM
NGK BPR6ES and you can try 30thou
Go to the full post
25 replies to this topic
#16 DILLIGAF
DILLIGAF
  • 3,615 posts
Posted 17 August 2013 - 12:40 PM
They dont require them, you need to brush up on a few of current electrical developments which have happened since you last looked.
Thats my point exactly, read what the op said there the leads he has............So he wants un suppressed plugs, which means BP6ES.....
NOT BPR6ES.......... Unless he wants to through out those leads and get new Unsuppressed leads..........
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 August 2013 - 01:58 PM
I said "They dont require them"  only in response to you saying use BP6ES. So you need to read what I've written !
You need to brush up on your knowledge on HT Electrics as now the leads are Inductive suppressed, not the older type. The Japanese car manufactures have had them since the late 70s as standard, as are the bulk of Ignition Leads sold by Minispares for the A Series.
I have just connected my car up to the Crypton and ran up 2 sets of plugs on the Oscilloscope, one Resistor and One Non Resistor, the leads are resistive inductive leads and on both sets the reading are between 18-20kv and no difference. The coils a Lucas Sports coil with a 27KV Max output, but there is only 18-20kv requirement to jump the plug gap at idle.
Edited by KernowCooper, 17 August 2013 - 02:16 PM.
#18 robminibcy
robminibcy
  • 1,516 posts
Posted 17 August 2013 - 02:57 PM
hi, I got the resistor plugs and she's running just as well as yesterday (very well!) i can't tell any differance with the radio although I've never noticed any problems or interferance before anyway. Cheers for the help. Also were much cheaper than usual at just over £4 with trade card so I will probably use these from now on!
#19 TehMarchant
TehMarchant
  • 628 posts
Posted 17 August 2013 - 04:51 PM
£4 each or as a pack of 4?
#20 robminibcy
robminibcy
  • 1,516 posts
Posted 17 August 2013 - 06:29 PM
£4 for Pack of 4! I think they are 17 normally.
#21 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 17 August 2013 - 08:05 PM
£17.00?? that sounds like a halfords price ;-)
#22 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 06 September 2013 - 08:52 AM
Could I use NGK BP6E plugs in my SPI if i have resistive leads? Or should I stick to BPR6ES plugs? Just wondering as I have a set laying around and need mine changing
#23 jaydee
jaydee
  • 8,565 posts
Posted 06 September 2013 - 10:19 AM
I'm afraid it could give problems to the ecu due to the RFI.
Not too sure because theres not such a big difference between normal and R type NGK plugs and from memory SPi engines were fitted with high resistance HT leads.
#24 IainStallard
IainStallard
  • 1,114 posts
Posted 06 September 2013 - 06:11 PM
From what I've read, you shouldn't use resistive leads and resistive plugs together?
#25 jaydee
jaydee
  • 8,565 posts
Posted 06 September 2013 - 06:58 PM
You cant run them together with points and condenser ignition, especially if using a ballasted coil.
The spi is electronic ignition run by the ECU, and i dont think they fitted copper leads from the factory
#26 IainStallard
IainStallard
  • 1,114 posts
Posted 06 September 2013 - 07:00 PM
Ah ok, sounds like I'll have to stick with BPR6ES plugs then
