hi everyone
i have a 1976 clubman that i am turning in to a roadgoing rally car. i ahve just bought a turbo head + all the other turbo bits,
i was wondering if i can just slap it on a standard 1275 A+. or would i need to change pistons etc?
turbo conversion advise,
1976 clubamn
, Jun 16 2004 06:23 AM
8 replies to this topic
Posted 16 June 2004 - 06:23 AM
Posted 16 June 2004 - 01:33 PM
It is possible to Turbocharge your existing engine, providing it's in good condition it should be fine. There are however a few things to consider.
Depending on the compression ratio of your engine you may need to lower it. You will need to use the Turbo carb, fuel pump, regulator, inlet & exhaust manifolds and the Turbo dizzy.
As regards your pistons, they should be able to withstand "modest" boost levels, but as i've never tried this on non Turbo pistons i couldn't say what was a safe level. I guess it's one of those try it and see areas ....
Phil.
Phil.
Posted 16 June 2004 - 06:57 PM
cheers for the advise
i do have all the nessasary parts to do this conversion, and a do have three 1275 A+ engines so i think i will see what the maximum boost a standard one can handle, if it blows it blows.
i will post later when i have tryed this to let you know what happens.
Posted 17 June 2004 - 12:13 AM
should be interesting
Posted 18 June 2004 - 01:30 PM
should be orate to run bout 7-10psi i reckon, not much more because the std turbo lump dont like running much more than that,unless someone wants to correct me.
Posted 18 June 2004 - 03:25 PM
The limiting factor for boost on a standard Metro Turbo engine is the compression ratio, this is 9.4-1. Raising the boost much, if at all above the standard 7psi will only lead to detonation.
The Turbo pistons are man enough for a lot more than standard boost, but the pistons in the normally aspirated engines have a thinner crown, so i'm unsure how much boost it would be safe to run on these ?
Phil.
Phil.
Posted 18 June 2004 - 07:03 PM
i have started striping down the block now so i may aswell put some turbo inerds into it, any advise on cams?
i really apriciate the help guys.
Posted 25 June 2004 - 01:03 PM
For a road motor i would try something like Kent 266, normally aspirated MG Metro or Avonbar Phase 2 cams.
I have run the phase 2 it is excellent !!
Phil. :grin:
Phil. :grin:
Posted 04 July 2004 - 05:33 PM
im running a BP270... or shall i sawy, "will"be running.
