Coil Confusion ?
Posted 03 September 2013 - 07:39 PM
Posted 03 September 2013 - 07:47 PM
Leccy dizzy or aftermarket kit?
Posted 03 September 2013 - 07:54 PM
Posted 03 September 2013 - 08:01 PM
sounds as if the garage have done a 12v coil conversion and correctly too so basically you used to run ballasted ignition and now you are unballasted.
Posted 03 September 2013 - 08:05 PM
You definately need to check if its got a leccy dizzy like a 65dm4 or its just a 'standard' points & condenser dizzy converted with an aftermarket kit.
If its an aftermarket conversion, you can run a sports coil, if its a 65dm4 you will burn the ingition module, that dizzy must be run on 0.8 ohm coil only.
this is a 65dm4 dizzy, notice the black box on the side of the dizzy, thats the ingition module:
Heres whats inside the cap of a common aftermarket kit for leccy conversions:
Posted 03 September 2013 - 08:11 PM
Posted 03 September 2013 - 08:12 PM
Posted 03 September 2013 - 09:05 PM
Cap is a screw type which was introduced with the 65DM4 and the distributor body is a 2 piece design, so I assume in the darkness there is also a module on the side, in which case you need the special coil which is a GCL 143
If you dont get the correct coil on it then its going to kill the module.
Edited by KernowCooper, 03 September 2013 - 09:16 PM.
