Cheers guys appreciate it
Also just want to check is it right that the amp live is strait from the battery with an inline fuse, will this not kill the battery ?
Edited by leepol83, 07 September 2013 - 09:11 PM.
Best Answer leepol83 , 10 September 2013 - 05:58 PM
Just found these on fle bay anyone had experience with these and will these need to be in a box or will they be ok under the rear seats.
Also don't suppose anyone can tell me which connections on the fuse box I need to connect the permanent live and the switched live to for my head unit can't for the life of me find my multimeter
Go to the full post
Posted 07 September 2013 - 09:03 PM
Posted 07 September 2013 - 10:03 PM
Posted 08 September 2013 - 01:00 PM
Brilliant thank you mate so I basically need to get all the blue wires back to the head unit the rest can be done from the back is that correctLive straight to battery with inline fuse ( the amp will not be live until head unit is turned on been as you have a thin blue wire that is remote turn on ) black wire is earth straight from battery or earth to a good body ground . Thin blue is remote to head unit and the RCA' s from head unit to the amp . If you get confused ask me anything .
Posted 08 September 2013 - 07:06 PM
Posted 08 September 2013 - 08:07 PM
Posted 10 September 2013 - 01:55 PM
Cool! Will I need to enclose these or will the boot be a good enough box for them.Yes that's all you do . Subs will be ace on parcel shelf but you will need powerful amp/s but would rock !!!
Posted 10 September 2013 - 01:59 PM
im thinking the small boot of a mini will act as a box. try it and i think it will be ace
Posted 10 September 2013 - 02:00 PM
i have 6x9.s mounted on the rear shelf down ito the boot and they sound good without a sub.
Posted 10 September 2013 - 02:10 PM
Sounds good I'm putting 2 6x9 under the rear seat and 2 more at the front but really would like a coup,e of subs just for pure bass I'm not that clued up on sound systems at all. If I went for these subs what amp would you recommend to run themi have 6x9.s mounted on the rear shelf down ito the boot and they sound good without a sub.im thinking the small boot of a mini will act as a box. try it and i think it will be ace
Posted 10 September 2013 - 02:36 PM
Thanks for all you're help buddy.
I would imagine so yes. The boot will prlly be too larger volume of air for those two subs, so they may not play to their full volume (db) because there not it right size enclosure (too big, yes, even a mini boot!).
If you did want to do what you where suggesting, which is running the subs infinite baffle on the parcel shelf, which means they don't need a box, then you need to find some different ones that can be run like that.
Posted 10 September 2013 - 03:22 PM
Posted 10 September 2013 - 04:18 PM
Posted 10 September 2013 - 05:58 PM Best Answer
Edited by leepol83, 12 September 2013 - 02:34 PM.
