Windscreen Will Not Fit
13 replies to this topic
#1 nrwilliams
nrwilliams
  • 133 posts
Posted 27 September 2013 - 06:59 PM
Hello all,
I am wondering if anyone has had a similar problem? The widescreen from my car is bigger than the apeture on one side. The apeture is 41cm tall on one side and 40cm on the other and I cannot get the screen to it.
It is the screen that came out of the car, the roof, pillars and scuttle have not been touched so I cannot understand this anomaly!
Any ideas?
Neil
Edited by nrwilliams, 27 September 2013 - 07:00 PM.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 27 September 2013 - 07:01 PM
Very strange Neil, it may be worth trimming some of the upper and lower flange at the affected end. I did that with Erm to even it up.
#3 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 27 September 2013 - 07:15 PM
What should the gap be? For when I fit my scuttle :)
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 27 September 2013 - 07:20 PM
I always fit the screen in before I weld the scuttle in just to check its right,
#5 nrwilliams
nrwilliams
  • 133 posts
Posted 27 September 2013 - 07:24 PM
Yeah it is odd. Will have to get trimming. I can only imagine it was either built like this or had a crunch (I suspect it has).
#6 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 27 September 2013 - 07:43 PM
I boobed when it came to Erms windscreen, i thought with it being a Heritage panel and lined up with the original it would have been ok but not the case.
Now i take measurements before a scuttle removal and mirror these when i fit a new scuttle. A lesson learnt for me and what minidaves has said would have been the perfect way to check.
However just had a thought here is the windscreen rubber a new one or the old one?? maybe a difference in manufacturing tolerances. I'm saying this as we used a brand new rubber on Erm. A possibility??
#7 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 27 September 2013 - 07:45 PM
Sadly the previous owner removed the full scuttle on mine.
#8 tiger99
tiger99
  • 8,584 posts
Posted 28 September 2013 - 10:36 AM
In your case I would suggest fitting an entire windscreen surround instead of just the scuttle. That way the dimensions will be correct. It comes with a vertical bar in the middle that should not be cut out until it is welded into the car, to keep it stable. It it does not fit the car, you will know which bits of the car to adjust.
The other advantages are that it gives you the opportunity to clean out, de-rust and paint the inside of the windscreen pillars, etc, and that you don't need to do seam welds anywhere, especially at the base of the pillars, where imperfect lining up is hard to disguise.
#9 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 28 September 2013 - 11:56 AM
No need for a full windscreen surround. I have the measurements of an unmolested window frame at the workshop. I will see if I can get them before work tonight.
#10 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 28 September 2013 - 01:30 PM
As promised the gaps for the windscreen,
At each end before the curve of the corners is 41 cm and then in the very centre it's 41.5 cms. This is flange edge to flange edge. This is top to bottom.
These measurements are taken from a 79 Mini Special.
#11 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 28 September 2013 - 01:38 PM
Cheers Neil  :highfive:
#12 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 28 September 2013 - 02:11 PM
No probs  :D  :D  oh and this was an original scuttle before anybody thinks it may have been changed in the past. ;D  It looked good on top but was crusty on the underside and the upper section of the bulkhead.
#13 nrwilliams
nrwilliams
  • 133 posts
Posted 29 September 2013 - 02:26 PM
I give up! Would it be too extreme to cut the windscreen pillar and extend it by 5mm?
#14 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 29 September 2013 - 02:41 PM
Neil you have a pm.
