Quickshift Problem
Best Answer wilz1234 , 28 September 2013 - 08:23 PM
From a couple of years back:
I found it easier to punch the original pins inwards. They seemed to be lightly tapered..........
Posted 28 September 2013 - 06:59 PM
Posted 28 September 2013 - 07:44 PM
Posted 28 September 2013 - 08:23 PM Best Answer
Posted 29 September 2013 - 02:01 AM
I have just done it on rod change. Punch the pins outward, works fine, just get a punch with a long and slightly bendy nose.. mine had about 5 cm narrow section
Posted 30 September 2013 - 10:31 PM
We had to take the whole exhaust off, manifold and all to get the bolt out of the top 'steady bar' above the linkage rod, then dad had great fun getting the roll pin out as we only have tapered punches, ended up using a long thin bolt and a cut down nail, then we got the selector housing and rods off, banged the pins inwards, and after the decision to put an imperial cleaning up tap through the housing to get 'a thread' we managed to get the purple sleeve to go down enough after lots of cleaning and emery clothing to get the bolts through, then all back together and it's brilliant!
image.jpg 40.67K 24 downloads
Posted 01 October 2013 - 02:34 AM
Gremlin - sorry, but had to laugh - don't you love these 5 minute jobs that end up like that.... 4 steps back then one step forward..
Posted 01 October 2013 - 06:15 AM
Simple answer is..
If you did not pay 90 odd quid for it, it's not a KAD, plus it'll say KAD on the top...
Which means you have a shocking Chinese made copy which will be a ******* to fit, not work very well, and once you ground this sh*t out of your gearbox, you'll be wanting a new one of them too...
See below.
Posted 01 October 2013 - 10:56 AM
They are not referred to as 'Quick-Graunch' for nothing.
The misconception is that they make the gear change faster, which is incorrect.
All they do is make the lever travel distance less. If the standard gear linkage is in good condition they don't really achieve much at all.
Posted 01 October 2013 - 04:56 PM
I had one in mine when I got it and took it out before it clapped the bulk rings and hubs, speak to John and pre book yours in, it will happen sooner or later, mine with the standard change is so much nicer to drive, the boys over at the Ford forum found the same with Bulk Rings and Hubs on the Ford boxes and they are usually bullet proof
Posted 01 October 2013 - 05:32 PM
To improve the gear change just make sure that the linkage is in top condition. Also, it is possible to make a modified rear support rubber mounting by getting an original Cooper/Cooper 'S' remote gear-change housing rear mounting and cutting it down to fit. without risking gearbox damage.
That also makes the linkage very positive.
I have used a KAD Quick-Graunch and quite liked it, but I was careful not to try to 'quick shift' when changing gear. On a bumpy road I found it easy to miss a gear as the movement is so short. In the end I changed to the modded linkage as above and found it much better.
Posted 01 October 2013 - 06:07 PM
Posted 01 October 2013 - 07:06 PM
Actually Cooperman your the first person on the forum I have ever seen call them 'Quick-Graunch'
But anyway as has already been said if its not a KAD one then really I wouldn't bother fitting it. When I bought my car it came with a cheap one fitted. Soon removed it and fitted a KAD one.
Edited by Sleepy Stu, 01 October 2013 - 07:06 PM.
Posted 01 October 2013 - 08:46 PM
The 'gaitor' you see in the picture above is a piece of an old landrover innertube - I wanted to be able to see the purple alloy housing
