Starting Engine Out Of Car
Best Answer wilz1234 , 29 September 2013 - 11:08 AM
Assuming it's not injected you only need a 12v supply across the coil which is broken by the points in the distributor. So battery +ve on the coil +ve, and a wire from the coil -ve to the points wire from the distibutor. Have the engine earthed to the battery -ve.
Make sure the engine is mounted solidly otherwise it could bounce around if it misfires
Go to the full post#1
Posted 29 September 2013 - 10:57 AM
Posted 29 September 2013 - 11:08 AM Best Answer
Posted 29 September 2013 - 11:49 AM
