i ordered the front subframe first, and then the rear but i also added on the extensions to the rear frame that allow you to bolt it into the front subframe. The front has the oval piece of metal on the front to bolt to the origional mini mounts but no hole in it to accommodate the rear mounting, could i just drill and tap and put an m12 bolt through it?
Connecting Rear Subframe To Front Mounts
fiestaharry
, Oct 05 2013 10:17 AM
No replies to this topic
