Hi,
Any assistance would be much appreciated.....
I have a 1970's 1275cc non verto clutch.
The clutch failed (pedal went to the floor very easily and the clutch arm was stuck open) - I've replaced: Release Bearing (it had collapsed), Slave Cylinder (was weeping), Top & Bottom Clevis Pins, Slave Cylinder Push Rod (old push rod had been extended).Hydraulic system has been bled.
The problem - When the clutch pedal is depressed it does operate the slave cylinder push rod but the pedal feels too light in that it doesn't feel as though the pedal hasn't moved the clutch arm far enough?
What is the best way to set up the non verto clutch (ie. setting up the clutch plunger gap/tolerance and the return stop gap/tolerance)?
Could the problem be that I need to extend the push rod or is there something I should do first?
Kind regards
Steve
