Please help,
Im having major dramas with my RH side lights. Ive got a 94' Spi cooper, standard loom (un-modified).
As you can see from my picture my drama is the connection from the side light switch to the in-line fuse.
when i switch to dip the front light up as normal but the rear RH still fails to light.
So im asking does anybody know where the join is as i need to check that or can i run a fresh wire to the in-line fuse from the red connection on the back of the lighting switch.
many thanks
Smudge
