Hey!
I just got my new camshaft, but it is a spider drive, and I got a 1991 998cc motor (so slot drive for the oil pump?)
How can I fit this camshaft? Are there any adapters to fit? Or a other oil pump??
grtz!
Posted 12 December 2013 - 12:48 PM
Hey!
grtz!
Posted 12 December 2013 - 01:27 PM
You need to get a spider drive oil pump and a spider.
Or a different cam.
Posted 12 December 2013 - 03:05 PM
Posted 12 December 2013 - 03:25 PM
You may be out of luck:
I think the spiders have been NLA for some time.
I'd give Mini Mail a shout and ask Tim - he is always my first port of call for odd stuff.
Posted 12 December 2013 - 03:46 PM
Yeah, and i still need the 'spider' to go on the pump as wel :/
Posted 12 December 2013 - 05:15 PM
For the pre-A+ 998 engines you also need to use a 6mm spacer plate between the block and the oil pump when using spider drive cam.
I don't know if this is the same for A+ 998 blocks, someone else on the forum may be able to confirm.
Posted 12 December 2013 - 11:26 PM
Errr... why ?
All cams are the same length, regardless of engine size, so why would you need to space the pump ?
You need to space an Auto block.
Posted 12 December 2013 - 11:47 PM
Posted 13 December 2013 - 11:31 AM
Mini Technical Sections →
Problems, Questions and Technical →
Milky Oil In Rocker After Not Draining Water Before Removing HeadStarted by jezjsa , 11 Mar 2024 engine |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Mini Now Wont StartStarted by jezjsa , 25 Feb 2024 engine |
Rough Running On Standard CoilStarted by Sweep16 , 09 Feb 2024 electrical, engine |
Duplex Timing Chain Sprockets Alignment IssueStarted by Timrobins , 22 Jan 2024 engine |
